Older Version K Manager
K20SV
Post by K20SV »
Hello
Recently a I bougth a new K20Z3 swaped EG K-Pro Equiped but I need to do some adjustments to the map ....but it seems like the Kmanager used for the previous owner was an older version of that I belive is 3.0.0.0. and the version I have installed on my laptop is the 3.3.1
Is there any way to get and save the map that the ECU has rigth now with the newer version of Kmanager? an upload again with the 3.3.1. version to get access to the map and do some adjustment to the map? if not...is there any archives of previos Kmanager versions?
Re: Older Version K Manager
You don't need the old version of KManager. The latest version should be able to download the calibration from the KPro. What type of KPro do you have?
You should be able to use the current version to read out the calibration unless it has been read protected by the tuner.
I'm not quite sure what you mean about the calibration being the same.
