Injector dead times
Posted: Wed Sep 17, 2014 7:00 am
I currently starting a fresh built engine and learning hondata at the same time.
Using injector dynamics 725cc injectors. I have put in the numbers from the chart supplied with the injectors at psi fuel pressure and the car seems to idle fine and run fine. When i turn on the lights and heater fan it AFR changes and goes rich.
would i require a longer dead time in the 12v cell of the table or shorter? Is there a better way to dial in injector dead times?
