Cold start issues
mholroyd
Cold start issues
Post by mholroyd »
Hello,
I'm a new user of Flashpro, with a euro civic fn2. I've had the car tuned by a professional tuning company but the car is quite jerky at low revs while cold. It was slightly jerky before the remap but now it makes it very hard to drive.
I was wondering if I could adjust the map slightly myself to fix these issues? I've spoken to the tuning company and sent a data log of the jerky behaviour, but he said "I've taken a look at the datalog and noted that although you open the throttle from 16 to 18% the throttle plate stays at 11%, even though the table value are around 6%! (See screen grab attached) I have experimented with increasing the numbers in the table to achieve better throttle response but have found that the car 'runs away'."
Does this mean my issues cannot be fixed (even though the stock map was fine)?
Martin
R-12914
Re: Cold start issues
Post by R-12914 »
Please post your Datalog and Calibration!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
mholroyd
Post by mholroyd »
Sorry. That would help wouldn't it. I can't download my calibration but I have asked my tuner to send me it. Hopefully that won't be a problem.
I have attached the datalog.
R-12914
Post by R-12914 »
For example:
To download the calibration where is currently on your Flashpro, using the "download" -Button in the Flashpro-window on primary or secondary calibration.
I need the Calibration to find out the problem, where you have!
Thanks!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
mholroyd
Post by mholroyd »
I tried, but it said 'flashpro does not contain a calibration'. I tried a few times, I then (regrettably) clicked 'read protect calibration' like a noob, misunderstanding what it would do... But the tuning company I used should be able to send me the map he loaded onto my car.
