E25 - VSS Out - What signal?
MartynL
Post by MartynL »
Hi guys,
Just wondering, for reference, what the 'VSS Out': Pin E25, outputs?
I know the signal 'pulses' depending on speed - just wondering what the nature of that pulse is - i.e. how many pulses per mph/kmh?
Thanks in advance,
Regards,
Martyn.
Re: E25 - VSS Out - What signal?
It is the same as the 02-04 VSS input, so about 4 pulses per wheel revolution.
MartynL
Post by MartynL »
Thanks - I'm guessing that when you select the 2005-2005 RSX setting in k-manager, the KPro applies a conversion factor to that? What would the output be in that case?
Many thanks.
Martyn.
Same. Both 02-04 and 05-06 clusters use the same input frequency.
balla_EG6
Post by balla_EG6 »
vss out only in auto ecu right ?
2004 EVO VIII - www.nrteam.org
Auto ECUs are not supported by K-Pro.
balla_EG6
Post by balla_EG6 »
I mistook, 05-06 has vss out. Im saying that cause I tried everything to make my cluster work without a vss conversion box (using 06+ SI vss with kpro 02-04).
