Boost control help
htownhatch
Boost control help
Post by htownhatch »
I dont think my boost control is working properly. I have tried to use the output test window and i do not hear my solenoid click at all. Im new to smanager and reading the data logs, can someone tell me how much boost im getting?
Thanks in advance
AREA876
Re: Boost control help
Post by AREA876 »
Using the output test window and varying the duty cycle and variable frequency you should both hear and feel the solenoid vibrating
AREA876
Post by AREA876 »
Which ECU are you using and does it have boost components installed
htownhatch
P28 and it does have all the boost components installed, ecu was socketed by hondata. I'll have to check my wiring.
htownhatch
ok so i found the issue with the wiring and have the solenoid firing with the "test outputs" window. Looking at my boost setup it looks like its set to 1% which would be the least amount of boost? is there anyway i can see what amount of boost i was hitting running off the wastegate and what percentage would it be on the boost control.
http://www.hondata.com/help/smanager/bo ... tsub=boost
see section: Pressure vs Duty Cycle
