Page 1 of 2
Acura RDX overboost code
Posted: Fri Aug 15, 2014 3:20 pm
by hypnotini
Modifications are cpe intake and flashpro.
Seems like my ecu has a "if boost > X then throw code" fault going on, I am looking to see if there is a way around this.
were not running max duty cycle and getting just a bit over 14psi tops with the flashpro and map settings for target are set high enough to read more psi then that.
Let me know if there is any specific information that would diagnose this.
I am including a datalog attachment.
Re: Acura RDX overboost code
Posted: Sun Aug 17, 2014 4:42 am
by the_wrench116
a copy of your tune would help. your data seems normal to me but I could very well have missed a few things.
Posted: Sun Aug 17, 2014 8:42 am
by hypnotini
Here is my current tune file.
Posted: Mon Aug 18, 2014 11:08 am
Are you getting a drivetrain protection fuel cut? Does this occur when in sport shift mode only? It is a two cycle error (it will show pending after the first time), so might be hard to track down to the point when it is occurring.
Posted: Mon Aug 18, 2014 8:09 pm
by hypnotini
it doesn't feel like a fuel cut, its pulling pretty hard. I will get some logs in D mode on wednessday and see if it pops up again. its not tripping any check engine lights so far except one time a while back but after clearing that and adjusting tune it just pops up on the datalog. I have other data logs where it is popping up also.
I did get a pop in my exhaust once also, trying to think outside the box if I damaged the cat and maybe its messing with the knock sensor, I am unsure seeing as many other rdx guys are getting 15-17 psi with no codes :-\.
I am stumped atm.
Posted: Tue Aug 19, 2014 12:52 pm
by VitViper
@Hondata
I can reduce the boost targets, and the error goes away, but then we're left with an RDX running basically stock boost... kind of shitty.
Posted: Tue Aug 19, 2014 2:30 pm
Can you tell us what ECU part numbers you are using?
Posted: Tue Aug 19, 2014 7:26 pm
by hypnotini
yeah do you want the car ecu and the hondata or just hondata. thanks for chiming in vit.
car ecu do I need to find on car or is it calibration id or cvn #?
hondata fp = fp-rdx-160047
Posted: Tue Aug 19, 2014 8:10 pm
No, it should be 37820-xxx-xxx
Posted: Wed Aug 20, 2014 2:26 am
by hypnotini
so not the 37805-rwc-a570 calibration id?
when I pick my car up from work today ill get the physical ecu code.
edit* read the faq ill get it today for you.
Posted: Wed Aug 20, 2014 9:08 am
by hypnotini
ok the rdx ecu# is - 37820 - rwc - a57
Posted: Wed Aug 20, 2014 11:49 am
It is a boost cut, but the Honda code is very complicated. It looks at both the turbocharger pressure and manifold pressure sensors, there are multiple compensations for throttle position, air temperature & rpm. I can expose the rpm vs map table but the turbocharger table is more difficult. Or I could just expose the minimum ect or rpm value, so effectively the overboost test would be disabled. Would that be ok?
Posted: Wed Aug 20, 2014 12:33 pm
by hypnotini
I would think that woyld be ok. Vits doing the tune work ill shoot him an additional msg
Posted: Thu Aug 21, 2014 1:13 am
by hypnotini
2 data logs after doing a battery cable ecu reset.
Posted: Thu Aug 21, 2014 7:13 pm
by hypnotini
so what is the next step
