Fuel Adjustment Overlay
gorechylde
Post by gorechylde »
Hey guys. I'm a little confused with the Adjustment Overlay. Are the positive and negative values displayed supposed to be in relation to my Target A/F or are those suggested changes to the fuel values?
i.e. -8= I'm 8% under my target A/F and need to add 8% fuel, or I just need to subtract 8% fuel?
If I'm reading this correctly, the wideband tuning guide: http://www.hondata.com/techwidebandtuning.html; shows subtracting from positive values and adding to negative values under the adjustment section.
Is that correct?
Re: Fuel Adjustment Overlay
It is relative to target lambda. -8% would mean to remove 8% fuel to get closer to your target lambda.
gorechylde
Excellent. Thank you for your help.
