Needing Basemap for 84mm Fully Built B18C1 with JUN3 CAM
CW-ITR
Post by CW-ITR »
Hi Guys and gals,
My first post here on this site and I need your help. My NA built motor (84mm Fully Built B18C1 with JUN3 Set Up) is scheduled for tunning this Monday and I need an S300 basemap for it. Here is my set up:
_ Benson sleeved 84mm B18C1 with Type R crank and API damper
_ 12:1 compression
_ TODA header
_ Hollow cat
_ Headgames Motorworks B18C1 head with standard Ferrea valves and Supertech springs and retainers
_ JUN stage 3 CAM
_ Edelbrock VictorX intake
_ 68mm Skunk2 TB
_ 440cc RC injectors
_Stock ITR tranny with 4.7FD
Thanks in advance and your help is much appreciated
hpmx18
Re: Needing Basemap for 84mm Fully Built B18C1 with JUN3 CAM
Post by hpmx18 »
you can start with ITR base and adjust fuel map accordingly till your able to get a steady afr on idle and should be able to tune immediately
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
CW-ITR
Post by CW-ITR »
Thanks "hpmx18". I was able to obtained a base map that work for my set up.
