Need n/a h22a4 basemap
Vtecdriver7
Post by Vtecdriver7 »
I have an h22a4 I have a 74mm skunk2 throttle body skunk2 intake manifold (not ported I know horrible just haven't got to it yet) aem high flow fuel rail aem adjustable fuel regulator set at 45 psi stock 290 injectors innovate wideband o2 sensor which I have wired into d11 ran on p28 with s300 the map sent with the ecu from ha motorsports barely runs I have been told I need to wire the o2 sensor into a pigtail harness but in hondata you can enable it to read wide and voltage through d11 so I don't know what to believe any help would be greatly apprieciated
hpmx18
Re: Need n/a h22a4 basemap
Post by hpmx18 »
load the preloaded map and adjust individual columns till it idle and rev's smoother and go tune
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
