Installing 07AT ECU in an 04 MT
EdmTSX
Post by EdmTSX »
Hey all,
I just recently purchased a brand new 07 AT ecu and flashpro from a member on tsxclub. I got the ecu installed at my Acura dealership and the flashpro manager reads everything fine and is up to date. When my friend at the dealership tried to immobilize the ecu and register the VIN, it comes up saying that he has to depress the brake and put the car in park. My TSX is manual so I can't exactly do that... How do I get passed this? Am I missing something or did my mechanic friend forget a step?
Thanks!
Re: Installing 07AT ECU in an 04 MT
You need a MT ECU for a MT TSX.
780mps3
Post by 780mps3 »
I thought i read somewhere that the new software from Hondata was supposed to be able to support AT ECU's in MT tsx's?
EdmTSX
Post by EdmTSX »
Hondata wrote:You need a MT ECU for a MT TSX.
Thanks for the reply but I think you're wrong.
This is on hondata's website and there are other TSX's out there running an AT ECU on their MT TSX.
- How does this work for the 04-06 TSX?
FlashPro does not work with the 04-06 ECU, so an 07/08 ECU is required. The Honda part numbers are 37820-RBB-A21 for the manual and 37820-RBB-A71 for the automatic. They sell for a little over $600 new. The 07/08 ECU plugs in and mounts where original ECU is located. Hondata provides a wiring adapter for $50 which links the ECU programming pins to the DLC. After the ECU is installed a Honda dealer will need to match the immobilizer to the new ECU.
07-08 MT swap ECUs are hard to find for my 04-06 MT TSX. Can I use an AT ECU?
Yes. FlashPro Manager 1.7.2 or newer allows a MT calibration to be written into an AT ECU.
What AT ECU part number is supported?
37820-RBB-A71
Will the AT ECU work the same as the MT ECU?
No. Reverse lockout does not work in an MT TSX using an AT ECU. This means you will need to be more careful on 4-5 and 5-6 gearshifts as you can inadvertently move the gearshift into the reverse plane.
Can I drive my MT 04-06 TSX with the AT ECU before programming it with the FlashPro?
Yes after the immobilizer has been synchronized. It is not recommended though. There will be error codes as the ECU is looking for an AT transmission. Shifting will not work well as the AT shift logic also affects the drive by wire.
I stand corrected. The AT ECU should work in a MT.
kenmaster
Post by kenmaster »
EdmTSX wrote:Hey all,
Thanks!
I got the same problem. Did you ever find out what's the problem was?
ef9b16a1
Post by ef9b16a1 »
hello i cant find a 37820-rbb-a21 for a customer with manual edm cl9 , so i will opt for the a/t a71 and lose the reverse lockout , so i ll then use the tsx flashpro and can adapter cable https://hondata.com/flashpro/flashpro-tsx , i see the above posters there was a problem with immo , did you finally suceeded to finalise the replace ecm (for immo)procedure for an a/t ecu in a manual car? The depress brake pedal and put in park promt that you state above that was needed was overrided e.g by just pressing the brake and having the car in neutral?
I have done the conversion on an M/T ECU , but not an A/T.
thanx
StealthTSX
Post by StealthTSX »
There is a major issue that Hondata does not address with swapping in the 2007-08 A71 auto trans TSX ECU into a 2004-06 manual trans TSX.
This swap will NOT work if you follow the Hondata instructions.
As other's have mentioned, when you install the auto trans ECU, the dealer will not be able to change the VIN number in it nor configure the immobolizer.
The dealer programming tool will require the vehicle to be put into "Park" which of course you can't since you have a manual trans in your TSX.
The answer is to add the "Park" pin and wire to the manual trans TSX ECU harness and ground it to tell the auto trans ECU that it is in "Park" and then the dealer can go ahead and configure the new ECU.
Luckily this is easy to do. You will have to find an ECU pin and wire from any wrecked 2004-08 TSX.
It's the D6 pin in the TSX ECU connector.
Further details in this www.TSXClub.com thread:
https://www.tsxclub.com/threads/07-auto ... 2/#replies
Let me know where the instructions are so we can update them.
StealthTSX
The instructions are on the Hondata website.
Go to FlashPro, then 2004-2006 TSX. "Hondata FlashPro TSX 2004-2006 with CAN adapter harness"
https://hondata.com/products/flashpro/f ... uage=en-gb
The 4th line down has a link to the installation instructions which are in .pdf format.
Under the FAQ tab there is info on swapping a 2007-08 auto trans ECU into a 2004-06 manual trans TSX.
While the 1st Gen TSX is now really old, there is still a strong following for these cars.
Thank you.
