immobilizer/fuel prime
Pogifresh
Post by Pogifresh »
Good Morning Hondata,
I have a 04 RSX type S with an existing PRB ECU installed in California. I recently bought a spare ECU 02-04 type S w/ K Pro v3 installed off k20a.org from a member in Minnesota and the installation was performed at Xenocron Tuning. I verified Xenocron installed K pro by finding the sticker and signature on back of the ECU cover & circuit board.
K Pro ECU sn: 37820-PRB-A05
2068-511272
K Pro sn: 14245
I have Kmanager software v3.3.1 installed, I installed the ecu w/K pro and the fuel pump doesn't want to prime. My car cranks but nothing, I disabled the immobilizer and still nothing. I re installed my orginal ECU and my car turned over and started up fine. I slaved the K pro ECU in again and tried to upload a kal but to no avail, engine cranks and turns over but will not start. I found the daughter board to be loose and re secured it and now the K pro green light lites up, but i have a faint red blink underneath it. I ended up swapping ECU's to original positions. Once I got home I inspected the installation and found the jumper wires to be skeptical and I came here to verify if the installation from the Xenocron technician was performed correctly or I'm doing something wrong in this switchology process.
Re: immobilizer/fuel prime
You should contact Xenocron about this, or try to get your money back from the seller as he may have sold you a damaged ECU or K-Pro.
Pogifresh
Post by Pogifresh »
Pogifresh
Post by Pogifresh »
is there a diagram or procedure i can follow so I can try and repair it on my own? I am a 2m technician in the navy and If you provide me the information I should be able to resolder the wires correctly and figure this out. I already feel I am out of the money and Xenocron says the warranty is void since I am not the original purchaser. Thank you
They should still take a look at it for you and can tell you if it is the ECU or the K-Pro that is the problem.
Pogifresh
Post by Pogifresh »
okay. I spoke with Xenocron and expressed the concern and prolly tomorrow or saturday Ill be sending my ECU and the spare ecu w/k pro in to be looked at and if it is a fuel pump issue in the faulty ecu they will install the k pro into my ecu for a fee and test it and send it back. thank you for the prompt response.
