jumper harness
Posted: Sun Jul 27, 2014 10:07 am
by hybridracer504
I have just recently bought a 06 rsxs and found that a wire on the jumper harness was broken by the pin. It was connector b pin 6. Can I send the harness back to you guys for repair or do I have to buy a new one. Reason I found it cause I was having trouble data logging. I am going to replace the spark plugs first to see if it helps out.
Re: jumper harness
Posted: Mon Jul 28, 2014 9:39 am
We are not able to repair the harness. It would be $150 to replace the harness if you send in the old one. You will need to call to obtain an RMA for this.
Re: jumper harness
Posted: Mon Jul 28, 2014 11:59 am
by hybridracer504
So how much is it if I don't send back the old one?
Re: jumper harness
Posted: Mon Jul 28, 2014 12:29 pm
$250 and you would have to send the ECU as well. Harnesses are not sold separately.
Re: jumper harness
Posted: Mon Jul 28, 2014 2:29 pm
by hybridracer504
O...ok
