MAP sensor install
MAP sensor install
ok, i need to find a 1/8" NPT fitting to go into the JRSC manifold where the JR pressure sensor was so i can hook the stock MAP sensor to it via a nylon hose (as supplied with the autometer boost gauge)as well as "T" it to the autometer gauge. anyone have suggestions where i can get the requisite items that my local home depot does not seem to carry? also, anyone have a plug or cap for the MAP sensor hle on the throttle? thanks!!
The pipe and vacuum fittings can be had at Ace Hardware or a similar decent hardware store.
A custom-cut aluminum MAP block-off plate can be purchased for $10 or so from most Hondata dealers. I got mine from Payn Technologies.
-Andy
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
