Firmware issue or something way worse?
93geezr
Post by 93geezr »
serial number: s300-0440 (green board)
- version of software: 2.2.7
- 98 Integra
- P28 with a OBD2 > OBD1jumper
I tried to download from the ECU to make modifications to my fan switch, but something wasn't allowing to do so. Additionally,
I couldn't make any adjustments to any other features (rev limiter, launch control, etc.), but my settings are still there.
When I clicked the "S300" tab the following errors occurred (see attached photo). Is it possible the firmware on the ecu
could be the problem or maybe the hondata is on it's way out due to the memory failure? FYI, the car runs, and I'm NOT the original owner.
Re: Firmware issue or something way worse?
Test on another laptop if possible. Is the 'Update firmware' option available?
93geezr
Post by 93geezr »
Hondata wrote:Test on another laptop if possible. Is the 'Update firmware' option available?
I didn't notice the 'Update firmware' on Wednesday when I did the update for the software, but I'll double check on another computer.
From Help, About, what version of software are you using now?
93geezr
Post by 93geezr »
I'm testing on another laptop, and there's no update firmware option. I'm still unable to update any of the parameters.
Spunkster wrote:From Help, About, what version of software are you using now?
Hondata SManager S300 ECU Editor 32bit
Version 2.3.3.0
Post a picture of the s300 board, make sure it is high quality and in focus showing the entire s300.
93geezr
Post by 93geezr »
Here's the picture as requested. LMK If a more detailed picture is needed, and
I'll have my friend with his SLR shoot it.
Download the most recent version of software from the downloads section of the website and then go to the Online menu and click on Erase ECU. This may takje several minutes to complete. When that finishes, close the program and reopen it then go to New Calibration and try uploading one of the calibrations listed there. See if that resolves the issue.
93geezr
Post by 93geezr »
Spunkster wrote:Download the most recent version of software from the downloads section of the website and then go to the Online menu and click on Erase ECU. This may takje several minutes to complete.
Ok, so I went ahead and "ERASED THE ECU," and tried to upload a new calibration. It goes to update the firmware, and it keeps going into a never ending loop of updating the firmware.
The new calibration seems to be not sticking, but I don't know for sure. FYI, I'm trying to upload a stock ITR map.
Please call tech support to obtain an RMA# and further instructions. Make sure you have the serial# when you call.
310-782-8278
mechhuff16
Post by mechhuff16 »
Did you ever get this resolved. im having the same issue.
