Vtec oil pressure solenoid
mapuSOHC
Post by mapuSOHC »
Hi,
Do i need to install a vtec oil pressure solenoid to my 2011 r18 civic?
a friend of mine who installed hondata like 2-3 years ago said he used a vtec oil pressure solenoid because a certain code i the system states that the engine cannot rev higher than 3,000rpm unless doing so..
RR with the weaponR
Re: Vtec oil pressure solenoid
FlashPro is not supported on R18 models outside the US.
mapuSOHC
Post by mapuSOHC »
I bought / ordered a USDM ECU along with the flash pro sir.
Is theres an option where we can just turn the code off?
the old flashpro (way back 2008) has no options to turn it off.
RR with the weaponR
