Boost and composite map
Posted: Fri Jun 27, 2014 8:28 am
by olivenoire
Hello
I've tune my car with 2 differents persons and with really 2 differents maps (I mean the composite map)
Actually I need some advice
my setup is :
k20 a fully build
eagle pistons
woesner pistons
and a little and old kkk k24 7200 turbo
good enough to handle 1 bar (15psi) from 4000-7200rpm.
max rpm is 8400
Vtec is somewhere beetween 4600-6500 depending on pressure
I want to know what is usually the best in composite map (for power or consumption)
Lot of cam angle more than 30° or not so much below 30°
Here 2 example of map
I know not exactly the same rpm index :(
Any advice?
First /
The first. The cars seems more smooth maybe less noisy, less vibration
The second. The cars seems more agressive, more vibration
Thank you for any comment
Re: Boost and composite map
Posted: Fri Jun 27, 2014 2:29 pm
by olivenoire
Bump..
No reply. Is my question understandable (or not)?
In fact I want to know if on a non N/A k20 it is good to have 30° or more for a turbocharged engine??
Why I'm asking this : when making some virtual dyno, it does not seems very different. After 30° the output power seems exactly the same
So for me not lose to much time tuning 30° and more, I 'd rather tune 0 to 30°?
TY in advance
