Boost Low/High table
DV8
Post by DV8 »
Hi guys,
trying to set up the boost by gear low/high tables. Have a switch wired up to the A/C which works fine.
Low boost table works fine - no issues. But with the high boost table i get a weird cut out no matter what i set it too.
Tested and tuned right up to 70% duty & at 70% fixed duty i don't get any cuts/stutters.
When 70% set in high table i get a weird cut issue.
Any insight appreciated. Log and map attached.
DV8
Re: Boost Low/High table
Post by DV8 »
I just wanted to add - in the log the AC switch is activated to high at 3:18. The 'cut/jump' can be seen at 3:24.
DV8
Post by DV8 »
I just noticed that the switch also activates the secondary table. Hopefully all solved now.
AREA876
Post by AREA876 »
Look back at your tables because column 14 needs to be tuned
DV8
Post by DV8 »
AREA876 wrote:Look back at your tables because column 14 needs to be tuned
On the Secondary table? I don't use that table at all and have disabled it.
