P2101 error code
keithd2959
P2101 error code
Post by keithd2959 »
Hi,
I am having a P2101 error code issue and the car goes to about 2000rpm on its own (safe mode?) ,until ignition is turned off and started back again.
Could it be the alternator or a faulty TP sensor ,actuator module or pedal module?
I use HONDATA Flashpro for datalogging.
Re: P2101 error code
It is the throttle body.
keithd2959
Thanks for the info. Before i change my throttle body, what is the minimum voltage expected during engine running? Mine is going down to 13V in the data logs, is this value normal? Thanks
keithd2959
just in case i have attached the data log with the error code in it. thanks
This would be the F3 car.
The P2101 error occurs at 2:56.300 & 3:09.725. 2:19 & 2:39 doesn't look right either, but no error was generated.
You're running in closed loop still? Short term trims are all over the place. MAP looks a bit low too - 22 kPa at idle is much lower than normal. Battery voltage at idle is a bit low too.
keithd2959
Hi, yes this is the F3 car. Thanks for the info.
Yes we are still running closed loop. We kept it like his cause its a 100% stock engine apary fron the exhaust. Alsi regarding the vaccumm i dont know what to say, as mentioned everything is stock on this engine. Any suggestions how to procced? Thanks
keithd2959
Hi, went through the data log again but i couldn't find anything wrong in the map, during idle its -22psi ( -157kpa) which i think its normal while in full throttle its nearly 0 which sould be fine right? thanks
Replace the throttle body first. Since the short term trim is high/low, it needs tuning.
keithd2959
Thanks, when you say tuning you mean fuel map adjustment right?
keithd2959
would it be possible to replace the original throttle body with a standard mechanical one? of course fitting a tps to it?
No, that will not work with the ECU.
keithd2959
so with the hondata its not possible to disable the electric throttle body right?
keithd2959
i am asking cause an original throttle body is quite expensive even a used one thats why
keithd2959 wrote:so with the hondata its not possible to disable the electric throttle body right?
Correct
keithd2959
thanks for your replies. much appreciated
