KPRO custom clutch switch in use with e22 ?
TJAPZ0RRO
Post by TJAPZ0RRO »
If I use e22 for FTS, will my brake lights light up when I press the clutch ?
- TJAP
Re: KPRO custom clutch switch in use with e22 ?
That input has nothing to do with your brake lights. They use a separate switch.
TJAPZ0RRO
Post by TJAPZ0RRO »
Spunkster wrote:That input has nothing to do with your brake lights. They use a separate switch.
Thanks Spunkster, I'm going to use e22 : )
TJAPZ0RRO
Post by TJAPZ0RRO »
Ah ok, I need +12v, what is the best place to get +12v on an EP3 ?
- TJAP
The best place for switched 12v is from the empty spots in the under dash fuse box.
TJAPZ0RRO
Post by TJAPZ0RRO »
Spunkster wrote:The best place for switched 12v is from the empty spots in the under dash fuse box.
Ok, going to use that spot in a while, currently I am using E29, because getting ground was the easyst (cel lights up when I press the clutch >.<) But now I am confused, I pinned only to E29 and my EPS icon flashes some times. Whats wrong ?
I'm sorry, but I'm not quite understanding your issue.
TJAPZ0RRO
Post by TJAPZ0RRO »
Spunkster wrote:I'm sorry, but I'm not quite understanding your issue.
The EPS and SRS lights flash, the only thing I did was ground the clutch switch and pulled a cable to E29.
This is the first time that they flash.
http://youtu.be/dkjJDHJdqaM
Undo what you have done and see if it acts normally. If it does it sounds like you have wired something incorrectly.
TJAPZ0RRO
Post by TJAPZ0RRO »
Spunkster wrote:Undo what you have done and see if it acts normally. If it does it sounds like you have wired something incorrectly.
I disconected the switch and the wire to E29, now the lights stoped flashing.
And I know for sure that my wire was connected to the switch and E29 only.
So I dont know why the lights flashed ...
Don't use E29, use one of the other inputs.
TJAPZ0RRO
Post by TJAPZ0RRO »
Spunkster wrote:Don't use E29, use one of the other inputs.
Like ?
Why not use E22 as you originally said you were going to
TJAPZ0RRO
Post by TJAPZ0RRO »
Spunkster wrote:Why not use E22 as you originally said you were going to
True,
Im going to try E22.
TJAPZ0RRO
Post by TJAPZ0RRO »
Ok, I'm pretty clue less at the moment, I've pinned from E29 to E22 and now it doesn't work .. And if I pin it back to E29 it works, so my switch is working .. If I in invert on E22 it works, always .. clutch or no clutch .. Whats wrong (I know for sure E22 was used) ?
Hope for some help ..
Edit: I switched the cable and input on KPRO ..
