OBD0 Code 20 fix Will this work ??
camshaft
Post by camshaft »
So for a OBD0 ECU
Code 20 ELD elctronic Load Detector
for obd0
From B19 to C13 and the other would be B19 to C12
obd1
Wire a 1k resistor from D10 to D20, and another 1k resistor from D10 to D22. The exact resistors values don't mater as long as they are the same and between 1k and 5k. e.g. you can use two 2.5k resistors.
for obd0
some one tell me I'm right or wrong.......
