What injector opening time for RC 750cc injectors on FN2 S/C
R-12914
Post by R-12914 »
Hi, i have an Rotrex supercharged CTR FN2 with RC 750 CC injectors and how are the parameters for the injector opening time in Hondata Flashpro specifically for this injectors and injectorsize?
Thanks!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: What injector opening time for RC 750cc injectors on FN2
Injector size 750cc
Dead times should be
6.00 8.00 10.00 12.00 16.00
3150 2104 1438 1080 672
R-12914
Post by R-12914 »
Thanks!
What fuel pressure i must use, what overrun injector restart rpms (cut) and what overrun injector restart rpms (recover) i must use for this injectors (RC 750CC).
Is a retune necessary?
Thanks again!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
The settings are for a standard fuel system - if you've converted to a return system then try 50-55 psi, and you may have to chance the overall fueling.
The overrun restart should be ok stock.
R-12914
Post by R-12914 »
Ok, thanks! :)
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
