Hondata Boost Control Solenoid Wiring Question
Posted: Thu May 22, 2014 2:32 pm
I am waiting for a pin to arrive since Hondata does not provide the wiring necessary to add the pin (receptacle on B16). I am aware that I will run a wire with a 10A fuse to the solenoid from this pin but I am wondering where do I connect the ground. Do I need to use one of the switched grounds on the ecu and if so which one? There are a few. Or do I simply ground to the chasis?
