Engine swap help!
speed614
Engine swap help!
Post by speed614 »
I recently swapped a 2001 GSR into a 2000 civic EX. The 2001 GSR ecu has the immobilizer system, do i needa spend $215 to get that removed or would it be possible for me to use a 96-99 ecu? Im using the engine harness from a 99 or 00 civic SI. Thanks
Blazzik03si
Post by Blazzik03si »
Since you are using the 99-00 Si harness you should just get another ecu and then have hondata mod it.
