Electrical Load AFR Issue
Posted: Sat Apr 12, 2014 10:18 am
Hi Guys,
Hoping someone can help as i'm stumped (again).
Getting quite a large AFR change as i turn on the lights, interior blower, stereo & rear screen demister. As i add load to the system the mixture leans out going from 12:1 right down to 15:1 roughly.
I've added the dead times supplied by grams for the 550cc injectors (see below) which didnt help. Ive also added some more grounds in the engine bay.
I did notice that when the indicators/turn signals are on the walbro fuel pump seems to pulse in tune (also the fuel pressure changes in time).
I've included the map and datalog - recorded on idle starting on nothing turned on and then adding load (starting with rear demister). AFR is also recorded from the AEM UEGO.
Thanks in advance for any thoughts.
