Flashpro failsafe input
peshinho
Post by peshinho »
Hello. Is there any way to use a ecu pin as a fail safe input for example for a water-meth kit fail safe?
If not. Is there any way to use kpro in a 2009 civic si?
I am ok to do whatever necessary to have kpro as using my ecu along with a tsx ecu and kpro. As I want all the car gauges working. Has this been done?
I know I will have to use a drive by wire tb, replace the o2 sensor, and something with the tsx harness
Please let
Me
Know. Thanks a lot.
Facundo
Re: Flashpro failsafe input
No, and no, you can't use a KPro on a 2009 Si.
emilorza
Post by emilorza »
is there a way to dump fuel if say IAT read above a certain point? I assume temp would spike if meth/water stops flowing. I need to use this as a failsafe
thanks
Emil
