How to use new S100 EPROM
Posted: Sat Mar 29, 2014 8:36 am
Hello,
I would be very thankful if someone can provide me with some info on the current version of the S100.
I received an Hondata OBD1 socketed ECU but instead of the usual black 27SF512 I got a green version looking like a small board.
1. There are some male pins with this new EPROM version, however these are too thick to fit into the socket which was soldered in the ECU, how is that supposed to work together?
2. Is it correct that s100 board (the newer version which is longer than the previous) does only work with this new version of the EPROM? I tried to use it as an interim solution with the Romulator, but that does not work.
3. How is the new EPROM being programmed? Just put in the male pins and burn as usual with the pocket programmer?
Is there anything else that should be known/done?
Thanks a lot in advance gents.
Andreas
Andreas
