How to install AEM a/f gauges in hondata?
tommychan0302
Post by tommychan0302 »
i tried put the white cable to eld ,but the a/f is not same with my aem gauges
how can i do?
anyone have the detail for install the aem gauges?
now i just can watching the aem a/f to tune my car,
i want to use datalog.
and i want to set a switch to open the sec table,
anyone have the photos tech me how to install the cable to ecu then open the sec table?
i want all of the detail
(p.s i,m just a new hand of car)
Re: How to install AEM a/f gauges in hondata?
Instructions for the PlX can be found at: http://www.hondata.com/techplxwiring.html
Just substitute the colors of the wires you have.
Details on the secondary tables can be found at http://www.hondata.com/help/smanager/se ... =secondary
Whatever input you use can no longer be connected to its original location. You are just inputting the switched signal into that pin on the ECU.
tommychan0302
But me is using obd2 to obd1
i tried to put the cable to eld (obd2) just follow the service manual
So I need from hondata ecu d10 pin then follow the cable which one is eld?
And my connect is correct ,I will see the lambda convert in setting form v to a/f automatic?
If you have an OBD2 to OBD1 adapterhjarness just tap into the wire in the adapterharness on the OBD1 side of the plugs. You must also have the software set correctly for the input you are using and the wideband you are using.
