Fuel tables absent???
Posted: Mon Mar 17, 2014 7:26 am
by Stez
Hello, im pretty new to Flash Pro, i have Civic Type R 2007 Euro. I opened stock equivalent calibration and could be able to see the main fuel tables for Low and High points, the only thing this calibration has is WOT afr low and WOT afr Hight... is this normal? or i should turn on something to see the Fuel tables ? Should we tune fuel only with WOT afr tables??? or how can we tune fuel?
Re: Fuel tables absent???
Posted: Mon Mar 17, 2014 10:33 am
That is an AFM based calibration and dows not have regualar fuel tables. IF you want to tune via map you will have ot use one of the race based calibraitons.
Posted: Mon Mar 17, 2014 10:45 am
by Stez
Spunkster wrote:That is an AFM based calibration and dows not have regualar fuel tables. IF you want to tune via map you will have ot use one of the race based calibraitons.
We have full exhast + CAI + TODA cams on the car and need to tune it, will this WOT afr tune will be anough to tune fuel or we will need to use MAP calibration to tune the car in our case?
Posted: Mon Mar 17, 2014 11:23 am
You should use a race calibration to tune this.
Posted: Mon Mar 17, 2014 11:47 am
by Stez
Ok thanks !!
Posted: Wed Mar 19, 2014 4:25 am
by nunoctr
Spunkster wrote:You should use a race calibration to tune this.
sorry but no.
He should use AFM calibration with map fuel tables.
Open an AFM tune, open "fuel" and the check the "use speed/density (MAP) fuel tables"
uncheck "AFM enable".
Then tune the fuel with MAP fuel tables.
Posted: Wed Mar 19, 2014 9:23 am
I'm sorry What I meant to say was you will need to enable MAP based tuning like a Race calibration in one of the calibrations with RSP in the name.
