Page 1 of 2
need b20z 60-1 rc550 map please
Posted: Wed Feb 26, 2014 11:38 am
by ef8904
stock 00 crv ex bottem
96 integra ls head
turbonetics 60-1
log manifold
walbro 255
rc550
stock fpr
aem fuel rail
any help would be greatley appreciated, cant seem to find a stock b20 turbo map
Re: need b20z 60-1 rc550 map please
Posted: Thu Feb 27, 2014 8:09 am
by throwdown
I can give you a base map but it would only be to start the car and drive it to be tuned...I don't recommend any WOT pulls just lmk
Posted: Thu Feb 27, 2014 11:22 am
by ef8904
hey i apprectiate the help. here are my datalogs and the map i guess from what i started with. b20 stock map created boost tables then added 20 % fuel in column 7 and 10
Posted: Fri Feb 28, 2014 8:20 am
by throwdown
I would take it straight to your local tuner
Posted: Fri Feb 28, 2014 4:29 pm
by keto06
I actually just tuned a B20 Turbo on the dyno yesterday. I will post the map when i get home.
Posted: Sat Mar 01, 2014 11:38 am
by keto06
He made like 236/219 @ 9lbs on a Mustang Dyno.
We kept the map fairly conservative and its tuned for a daily driver on 93 octane.
AFRS are around 11.3-11.5 across the board in boost.
Posted: Sat Mar 01, 2014 3:37 pm
by ef8904
Thanks for the quicl reply, ill flash my ecu and update later tonight. Can't wait!
Posted: Sat Mar 01, 2014 5:42 pm
by ef8904
Anything I should do aside from relearning TPS, turned wideband input on ELD and timing at 16? RC injector dead times? Should I tun open or closed loop?
Posted: Sun Mar 02, 2014 4:04 pm
by ef8904
Worked out well! Switched to a colder plug and runs great WOT. Which turbo was it running?
Posted: Sun Mar 02, 2014 4:25 pm
by keto06
Awesome.
Always open loop.
6s or 7s? This was tuned on 6s. Forgot to mention that.
If you hookup the wideband, post a log. Id like to see it.
It was running a GT35.
Posted: Mon Mar 03, 2014 1:57 pm
by ef8904
i went with 7s. i believe my WG has a 7lb spring as well. Was that a low or high compression b20? does it have headstuds? ill drive the car tonight and do my best to log it. thanks again for the help, car is a blast to drive now!
Posted: Mon Mar 03, 2014 2:21 pm
by keto06
7s should work, though I think youd be fine with 6s.
I believe its a completely stock B20 out of a CRV. They might have put in headstuds but I dont think so. Stock intake mani, log style turbo mani. Very simple build overall but he likes it.
Should be fine running 7lbs.
Posted: Tue Mar 04, 2014 2:48 pm
by keto06
Datalog?
Posted: Wed Mar 05, 2014 6:24 am
by ef8904
here ya go. sorry it took so long, i only have a computer with net at work. hopefully this worked properly
Posted: Wed Mar 05, 2014 10:26 am
by ef8904
actually after reviewing my own log that is probably no help. ill try again tonight and find an open road to pull in 4th
