need b20z 60-1 rc550 map please
ef8904
Post by ef8904 »
stock 00 crv ex bottem
96 integra ls head
turbonetics 60-1
log manifold
walbro 255
rc550
stock fpr
aem fuel rail
any help would be greatley appreciated, cant seem to find a stock b20 turbo map
throwdown
Re: need b20z 60-1 rc550 map please
Post by throwdown »
I can give you a base map but it would only be to start the car and drive it to be tuned...I don't recommend any WOT pulls just lmk
ef8904
Post by ef8904 »
hey i apprectiate the help. here are my datalogs and the map i guess from what i started with. b20 stock map created boost tables then added 20 % fuel in column 7 and 10
throwdown
Post by throwdown »
I would take it straight to your local tuner
keto06
Post by keto06 »
I actually just tuned a B20 Turbo on the dyno yesterday. I will post the map when i get home.
07 Civic Si Sedan (sold)
17 Civic Si Sedan (daily)
02 RSX Type S (project)
Hit me up for free Hondata Help!
keto06
Post by keto06 »
He made like 236/219 @ 9lbs on a Mustang Dyno.
We kept the map fairly conservative and its tuned for a daily driver on 93 octane.
AFRS are around 11.3-11.5 across the board in boost.
ef8904
Post by ef8904 »
Thanks for the quicl reply, ill flash my ecu and update later tonight. Can't wait!
ef8904
Post by ef8904 »
Anything I should do aside from relearning TPS, turned wideband input on ELD and timing at 16? RC injector dead times? Should I tun open or closed loop?
ef8904
Post by ef8904 »
Worked out well! Switched to a colder plug and runs great WOT. Which turbo was it running?
keto06
Post by keto06 »
Awesome.
Always open loop.
6s or 7s? This was tuned on 6s. Forgot to mention that.
If you hookup the wideband, post a log. Id like to see it.
It was running a GT35.
ef8904
Post by ef8904 »
i went with 7s. i believe my WG has a 7lb spring as well. Was that a low or high compression b20? does it have headstuds? ill drive the car tonight and do my best to log it. thanks again for the help, car is a blast to drive now!
keto06
Post by keto06 »
7s should work, though I think youd be fine with 6s.
I believe its a completely stock B20 out of a CRV. They might have put in headstuds but I dont think so. Stock intake mani, log style turbo mani. Very simple build overall but he likes it.
Should be fine running 7lbs.
keto06
Post by keto06 »
Datalog?
ef8904
Post by ef8904 »
here ya go. sorry it took so long, i only have a computer with net at work. hopefully this worked properly
ef8904
Post by ef8904 »
actually after reviewing my own log that is probably no help. ill try again tonight and find an open road to pull in 4th
