just out of curiosity...noob question??
protoge91
Post by protoge91 »
when you disconnect the battery and reconnect it does it still have the map that was uploaded prior to being disconnected or does the kprod ecu revert to something else?
n??2002 acura rsx type s k20a2
2002 DSM ACURA RSX TYPE-S / K-PRO / PWJDM INTAKE / OBX V2 HEADER / HASPORT MOTOR MOUNTS / INGALLS ENGINE TORQUE DAMPER / K-TUNED BILLET SHIFTER / SCHROTH RACING HARNESS / ENERGY SUSPENSION
Re: just out of curiosity...noob question??
Disconnecting the battery does not change the program/map/calibration in the ECU.
protoge91
Post by protoge91 »
OK COOL thanks...and also is 8 knocks on my datalog a bad thing? i know there are an exceptable amount of knocks but idk what it is.....
That depends on how long the datalog was.
protoge91
Post by protoge91 »
Spunkster wrote:That depends on how long the datalog was.
can you take a look at this datalog??? thanks man
Some knock at 7500 rpm, but the AF needs tuning. -20% trim in places, WOT AF is full rich.
protoge91
Post by protoge91 »
Hondata wrote:Some knock at 7500 rpm, but the AF needs tuning. -20% trim in places, WOT AF is full rich.
so me and a street tuner learned yesterday that what was making things so chaotic in the a/f ratio was my new 88a hasport motor mounts. my brand new knock sensor was picking up all the new vibrations as knocks. so when we disabled the knock sensor right away it was a night and day difference the car ran so much smoother and the af ratio was once again smooth instead of peaky. so i guess ill go back to the toda headers map in a few days and see how it feels.
but for now the knock sensor is disable and im running in an a/f ratio that he said was too safe for knock so we are all good...?
i still plan on gettin professionally tuned
The engine vibration does not affect the AF - it needs tuning. I would not disable the knock sensor without first identifying areas of knock, retarding the ignition in those areas, and seeing if it makes a difference.
protoge91
Post by protoge91 »
Hondata wrote:The engine vibration does not affect the AF - it needs tuning. I would not disable the knock sensor without first identifying areas of knock, retarding the ignition in those areas, and seeing if it makes a difference.
well according to the guy at precision autoworks the sensitive knock sensor records false knock and tells the engine to add more fuel and retards timing. with the knock sensor disabled the air fuel ratio was much smoother. i mean i saw the datalogs with my own eyes but as to the explanation i am not really sure sounds like it makes sense
