05 ctr jrsc map
Tommyreed
05 ctr jrsc map
Post by Tommyreed »
Hi, was wondering if any kind of map for a jrsc fitted to my ctr, it has rc650 injectors and a arm v2, would just like to get car running safely for now,
Or. Can I use the map that's on kmanager? It's a jrsc map for 440cc injectors can I just alter that to 650cc ?
Much appreciated tom
Tommyreed
Re: 05 ctr jrsc map
Post by Tommyreed »
Right okay,....if this is not enabled I could cause engine damage?
yeah The ecu is the PRA euro civic type r thanks for the reply.
Tommyreed
Re: 05 ctr jrsc map
Post by Tommyreed »
yeah sorry that was the map i meant, i read in the help, that when you change injector size, all the fuel tables are automatically changed, so really i shouldnt get any knock from changing this map, but yeah i will turn on mil light to flash if knock is detected.
yeah i am able to datalog. if i can set it up with no knock, how long do you think i could run it safely before getting it professionally mapped ? or will it be fine?
