Stage 3 cams, k20 build block, IHE
jbfd2ar
Post by jbfd2ar »
Hi guys, Anybody with similar setup ? Got a tuned map to share ? I am currently tuning my own car. Currently at about 36deg on column 10 on high. I dont dare to up it further. is it safe to go close to 40deg ?
NA
stage 3 cams
k20 12.5:1 compression ratio
Intake
Header
Exhaust
arraydude
Re: Stage 3 cams, k20 build block, IHE
Post by arraydude »
jbfd2ar wrote:Hi guys, Anybody with similar setup ? Got a tuned map to share ? I am currently tuning my own car. Currently at about 36deg on column 10 on high. I dont dare to up it further. is it safe to go close to 40deg ?
NA
stage 3 cams
Intake
Header
Exhaust
Which CAMS ?, try max 37degrees and lowering to 30 at high rpm, but you can go to a dynamometer to measure with what make more power...
In realiability terms i dont give more than 37deg
DatLife84
Post by DatLife84 »
Be careful that sounds like a lot of timing with the amount of compression you have. I just have drop in cams and 30 degs. was too much. The least amount of timing close to MBT is your best bet.
