cant seem to delete datalogs?
Posted: Fri Jan 24, 2014 6:44 am
Hi,
I have recently purchased an s300 but am having a couple of issues with it. It was understood to be a v1 but on smanager (latest version), it suggests that the ecu has 16mb onboard memory? does that not suggest it is a v2?
The main issue i am having though is that i matter what i do, i cannot seem to clear the datalogs from the ecu, each time i press the 'delete all' button, when i turn the ignition off and on again afterwards, more appear? The datalogs also appear to be corrupt, indicating rediculous thinsg like 65000rpm and 550psi map pressures?? also negative values in the datalog listings.
I have a screenshot which i can post later on but i was wondering if this has been encountered before??
Are there any visual ways of telling if the s300 is v1 or v2 if i open the ecu case?
Any help appreciated...
Neil
Neil
