Nitrous Control, Knock count maximum
sander
Post by sander »
Hello,
I was recently tuning a car that had a Knock Count condition maximum of 0 in the Nitrous Control -> Settings Tab. We were going to try a larger dry shot with pump gas. I felt safe being that if the Knock Count exceeded 0, the ECU would de-activate the relay that was powering the solenoid.
Long story short, this did not happen. See the log below.
I wasn't going to rely on the Knock Count de-activation for the long run, although I would have expected it to save this from happening.
Any info would be appreciated for the future.
Thanks,
-Sander
learning.
Re: Nitrous Control, Knock count maximum
A maximum knock count of 0 is disabled. Use 1.
sander
Post by sander »
You should have this in the Nitrous Help file, or explicitly written somewhere obvious.
learning.
I've changed the help file.
