Flashpro + Mac boost solenoid
Posted: Sun Dec 08, 2013 4:52 am
by dermeister
Hi,
Just made the car turbo, its an internal wastegate setup with a recently installed MAC solenoid. On your help file, the diagram is for an external setup, not internal. So I configured it as port 1 = breather filter , port 2 = internal wastegate, port 3 = turbo pressure.
On the flashpro should I select normally open or closed. Right now its set at normally open, but it wont boost more than 8psi (spring rate). Fixed duty was set at 70% - 80% with no change in boost.
I appreciate the help
Regards
Re: Flashpro + Mac boost solenoid
Posted: Mon Dec 09, 2013 10:47 am
Has your ECU been modified to add the components to the ECU for boost control?
Posted: Mon Dec 09, 2013 11:10 am
by dermeister
Yes. Ecu was sent and Everything is connected.
Today, I was making some tests and at 20% is boosting up. Apparently boost increases when decreasing the percent. I have boost cut feature active and selected "solenoid normally open", is this ok?
Regards
Posted: Mon Dec 09, 2013 11:28 am
Is this a Hondata solenoid?
Posted: Mon Dec 09, 2013 3:43 pm
by dermeister
No, Mac solenoid (identical one)
Posted: Mon Dec 09, 2013 4:13 pm
It may look the same but could be different internally. The one we offer is a normally closed solenoid.
Posted: Mon Dec 09, 2013 5:23 pm
by dermeister
Including picture of solenoid
Posted: Tue Dec 10, 2013 8:55 am
That is not the same as a Hondata solenoid.
