Injector Overrun Manifold Pressure Settings
Posted: Thu Nov 28, 2013 11:15 pm
I am looking for some guidance on setting up the injector overrun manifold pressures. The motor being used in this particular S2000 has a few major differences over a stock F22. The engine is a custom build, with increased bore, stroke (99mm) and compression (12.5:1). Also, the head has some mild work, including larger intake valves and an aftermarket cam. The throttle body is a J37 unit, and the manifold opening has been machined to match the TB outlet.
Therefore, the amount of vacuum vs. rpm under deceleration is no longer the same as the old F22.
Here is what I have in mind to tune the Overrun Manifold Pressure tables:
1) Datalog the following condition. Run engine to redline in 2nd gear, release throttle and allow the car to decelerate on its own down to idle (no brake pedal). Repeat this procedure in 3rd, and 4th gear, in order to determine any variance due to gearing, tire friction, aerodynamic drag, etc.
2) Analyze the MAP curves over rpm for deceleration in each gear. With this data, generate a curve using the highest kPa values seen under vacuum during decel.
3) Add approximately 2 kPa to the generated curve. Use the data points from this new curve to set new values for the "Overrun Cut Off MAP Low Cam (cut)" and "Overrun Cut Off MAP High Cam (cut)" maps.
4) Set both the Low Cam and High Cam RECOVER table values approximately 3 kPa higher than their CUT table counterparts.
Please provide comments and suggestions for this plan of attack.
