Kpro boost control problem
Posted: Wed Nov 27, 2013 10:58 pm
by xidmxi
I hooked up a Mac solenoid to kpro but it doesnt work.Its powered all the time when on II and disabling it from kpro doesnt make a diffrence it stays on.I heard both Wires going to the solenoid should have +12v and the ecu from pin b21 should ground to activate the solenoid but I tested pin B21 and its grounded all the time it never has the 12v. What could be the problem?
Re: Kpro boost control problem
Posted: Sat Nov 30, 2013 5:55 am
by 05typeR
Posted: Sun Dec 01, 2013 9:04 am
We're making a release in the next few days to fix this.
Posted: Tue Dec 03, 2013 1:27 pm
by xidmxi
Thanks!!!
Posted: Mon Feb 17, 2014 10:23 am
by turbosi05
I am having the same problem even with the new release. The solenoid pulses a few times when the ignition is turned on. Then stays on continuously afterwards.
Posted: Mon Feb 17, 2014 11:47 am
Have you uploaded your calibration using the new version of software?
Posted: Mon Feb 17, 2014 3:27 pm
by turbosi05
Yes
Posted: Mon Feb 17, 2014 4:27 pm
From Help, about, what version of software are you using?
Posted: Mon Feb 17, 2014 5:47 pm
by turbosi05
3.3.0.0
Posted: Tue Feb 18, 2014 10:35 am
Please post your calibration, as I cannot reproduce a problem here.
Posted: Sun Mar 16, 2014 5:58 pm
by Nineteendc5
I am having the same issue with the new 3.3.0
Tried it on 2 seperate laptops with 3.3.0, but i tried uploading the map on a laptop with 3.2.4 and it works perfectly. I need a fix asap!
Posted: Fri Jun 20, 2014 3:59 am
by maxime bougie
same problems with the new version
Posted: Fri Jun 20, 2014 9:03 am
The original problem was fixed some time ago. Make sure you have the latest software version, then follow the posting guidelines if you still have a problem.
