TPS Singal breaks away
Posted: Tue Nov 12, 2013 11:28 am
- Honda Civic Type R – ep3
- serial number of your K-Pro - 470
- ECU part number 37820-PRA-E11 and 966823-2Y23
- KManager version 3.1.2.0
- mods: injen cold air intake / RBC Manifold / Tegwia 4-2-1 RaceHeader/ Supersprint CatBack
- when and where you got the K-Pro – bought it second hand from the UK
- ground is on cylinder head
Hello,
i got a problem with my TPS Signal. See screenshot. When i keep the throttle control in a center position, after a few seconds or sometimes after 2-3 minutes, the signal breaks away.
I already replaced the TPS Sensor against a k-tuned and another sensor. I also tryed to put a new cable directly from the ECU to the TPS Sensor. Still the same problem.
When i measure directly at the tps sensor the voltage on Red/Black or Yellow/Blue it won´t break away. I only see it in the kmanager.
The main problem on that is, when i drive the car for 2 laps on the racetrack (Nuerburgring Nordschleife) after 1 ½ i dont get any TPS Singal anymore. Somehow this might has something to do with heat.
I tryed to re-create the problem by heating up the tps sensor and cables, but it didn´t worked out.
First of all i like to know why the tps signal breaks away even when the engine and everything else is cold.
Can the kpro somehow be damaged?
Also the kpro seems a little bit bend. See picture.
Thanks in advance!
Hello,
Thanks in advance!
