wont rev past 7,500 and injectors pulsing on decel. s2000
Posted: Sat Nov 09, 2013 10:29 pm
2000 Honda s2000
Hondata Kpro bought new in 2011 through Ramey Built of Virginia and installed there
ran into a problem about a 8 months ago, had my new tuner check it out without any luck. now after trying everything including injector clips, injectors, wire harness and 8 months of fighting with it I give up.
Problems:
1. will not rev past 7,500-8,000.. almost seems like its hitting launch control but even with launch control disabled it still limits at 7,500.. happens in every gear and if you are coasting and rev it in neutral.. also if you try to rev it at 1/4 or 1/2 throttle you can tell its starts to build a load up like as if you were sitting still hitting launch control.
2. sometimes on deceleration the injectors will stay open and pulse.
Ecu is up to date. there are no CEL and everything seems to work perfect according to datalogging ect. also have went over everything including taking apart the wire harness and checking for broken wires ect... have had no luck. is it possible that something in the actual ecu is bad or could it be something with the ecu not picking up the speed or maybe the TPS? i have seen others with similar problems with injectors pulsing on decel but no body with an answer and replacing the TPS didn't help. any input at all would be greatly appreciated. Thanks.
Problems:
