replacement wideband O2 sensor for closed loop
dennismfm
Post by dennismfm »
K pro III
Is it possible to do closed loop by replacement wideband O2 sensor?
How to wiring?
Seems k pro connected E15 pin with wideband O2 senaor only for datalog.
K pro III Analog input , digital input connect with wideband sensor can run in closed loop or not ?
dennismfm
Re: replacement wideband O2 sensor for closed loop
Post by dennismfm »
One more question.
When WOT full load,
the air /fule ratio will run WOT target A/F 12.5.
When WOT full load in open loop.
it is work with map sensor . & O2 sensor,
When I connected AEM AFR meter & wideband O2 sensor with e15 pin.
WOT will read AF ratio by E15 wideband O2 sensor ?
dropdeadrus
Post by dropdeadrus »
aftermarket widebands that are wired to E15 can't be used for closed loop
and 12.5 is not a target AF for WOT, that's the WOT compensation table!
dennismfm
Post by dennismfm »
How to use the analog wideband input for closed loop instead of the factory O2 sensor? Thanks
You cannot do this.
