why my tps drops when the revs goes up?
fugazzyek
Post by fugazzyek »
hi there,
looking my datalogs the tps drops almost in the same rpms 2000-3000 and makes like a hole, is already calibrated to 0 min and 101 max.
can anybody give some info, thanks
regards
gotslicks
Re: why my tps drops when the revs goes up?
Post by gotslicks »
do you have a datalog.
Without seeing a datalog and your calibration it's hard to say, but sounds like a faulty TPS sensor.
fugazzyek
Post by fugazzyek »
ok dudes here is the datalog after a work day, i already change the tps even use aftermarket bracket and nothing....
any help is well received,
thanks
TPS to MAP relationship looks normal. Where in the datalog is the problem?
fugazzyek
Post by fugazzyek »
at least i note on this part, am i wrong?
i hope you can advice me to correct it
What exactly is the problem?
Where in the datalog does it show the problem?
fugazzyek
Post by fugazzyek »
Hondata wrote:What exactly is the problem?
the tps is not proportionally to rpms when they are going higher???
here stay flats the tps... and i relate the fail with this on the data log
That looks normal - the TPS drops, and the MAP also drops, which shows the throttle plate changed.
I do see the TPS faulting at 3:26.95, where it drops out briefly.
