Hondata S300 not reading sensors
I go to the sensor tab and its not showing that its reading the sensors or the display tab. It wont read any errors if i have CEL on. What could this be?
Re: Hondata S300 not reading sensors
Problem fixed!Checked Ecu and still had resistor j12. Removed j12 and reads all sensors.
I know that you can use analog input or in the closed loop advance with a target lambda and you connect but i don`t know if you need anything else??
hi
