kpro won't hold the base map
Posted: Tue Sep 03, 2013 9:58 pm
by bpjeffrey
I have an 05 EM2 with a bone stock K20a2 swap, the only aftermarket parts I have is the conversion harness from Hybrid Racing and the Kpro. From the initial install the kpro wouldn't and won't hold the base-map once I turn the car off for 10min+!
Re: kpro won't hold the base map
Posted: Wed Sep 04, 2013 9:39 am
The calibration is uploaded to the ECU and it cannot loose the calibration even if the ECU is unplugged. Please give more detail of exactly what is happening.
http://www.hondata.com/forum/viewtopic.php?f=12&t=3629
Posted: Wed Sep 04, 2013 2:07 pm
by bpjeffrey
Okay Spunkster, When I installed the swap I completed in one day so I saved the start-up til the next morning. I uploaded a base type's map! It idled perfect and didn't drive it until the coolant system was bled. When I took it around the block it was running perfect. I turned the car off to clean my work space and when I went to start it it wouldn't rev past 4 and all the settings went back to "default"
Posted: Wed Sep 04, 2013 2:29 pm
Please provide all the information in the link above.
Posted: Wed Sep 04, 2013 4:31 pm
by bpjeffrey
Getting Info now
Posted: Thu Sep 05, 2013 10:10 am
by Shacqem2
- Serial number Kpro-12632
- ECU part number-37820-prc-013
- Serial number- 2070-300353
- KManager version-3.2.4
- Vehicle- 05 honda civic with a Bone stock k20A2 swap with a hybrid racing conversion harness and Kpro
- Problem- From the initial install the kpro wouldn't and won't hold the base-map once I turn the car off for 10min+!
-When and where you got the K-Pro?-August 22, 2013 from Project Jdm
Posted: Thu Sep 05, 2013 11:58 am
by bpjeffrey
Info is up Spunkster
Posted: Thu Sep 05, 2013 2:57 pm
Are there any error codes when it only revs to 4000 RPM when checked with datalogging?
Posted: Thu Sep 05, 2013 3:33 pm
by Shacqem2
P0113 IAT sensor high voltage
Daughter board communication error
Posted: Thu Sep 05, 2013 3:42 pm
by Shacqem2
The multiplexer was disabled.. and then I enabled it and it revs past 4k and now my temp guage works..
Posted: Thu Sep 05, 2013 3:43 pm
by Shacqem2
So what im guessing is that everytime my vehicle is turned off it disables the multiplexer..
The daughterboard communication error is your biggest problem and you will also need to resolve the IAT error as well. Check your battery voltage when cranking as it is probably too low and is causing the error. Your calibration is not being erased.
