Stock launch control setting for rsx type s 2002
gunja1
Post by gunja1 »
Hi yall,
The rsx type s comes stock with launch control at 4500 rpm. Same for the tsx.
Juste wondering if someone know the stock launch control setting for the rsx type s.
Ps : stock rsx type s 2002-2004 cal in k-manager does not come with the launch control activated but the stock rsx type s ECU comes with launch control activated.
Thanks.
Re: Stock launch control setting for rsx type s 2002
A stock RSX does not have launch control. It just has a 5000 RPM rev limit when the vehicle is not moving.
gunja1
Post by gunja1 »
Then, can I put launch control ? And wath setting should be the best ?
This is adjustable as what will work well for one person may not work for another. You will have to experiment and see what works best for you.
gunja1
Post by gunja1 »
If I set the launch RPM limiter to 3000 rpm, then the Fuel & Ignition retard activation RPM should be below like 2800 rpm or 2600 rpm ?
ps : the settings already written when I activate the launch control does not make sense
If you are NA, then you should not need to have any fuel or ignition changes for a launch limiter.
gunja1
Post by gunja1 »
Then I don't change anything ? Just enable it and try it like that ?
Ps : I don't know wath is NA !
naturally aspirated
gunja1
Post by gunja1 »
It does not work. I just activated it with stock settings but it does not work.
Post your calibration and a datalog showing it not working.
gunja1
Post by gunja1 »
I think that my datalog file is to big to post it on the forum (about 19mb) but here is my .kal
You can trim the datalog down, or make a shorter datalog. We need to see the datalog.
