2008 TSX VTC
Posted: Fri Aug 16, 2013 2:07 pm
by tH3 eL
Will a 2006 RSX Type S VTC mechanism, part number 14310-RBC-003, work with the Flash Pro? (Vice taking the existing mechanism to a machine shop.)
Thank you.
Re: 2008 TSX VTC
Posted: Fri Aug 16, 2013 4:40 pm
Re: 2008 TSX VTC
Posted: Mon Aug 19, 2013 5:06 am
by Zoro2006
tH3 eL wrote:Will a 2006 RSX Type S VTC mechanism, part number 14310-RBC-003, work with the Flash Pro? (Vice taking the existing mechanism to a machine shop.)
Thank you.
it will work, just don't go past VTC 45 in Hondata as you won't gain more and will have bigger clearances.
Re: 2008 TSX VTC
Posted: Tue Aug 20, 2013 1:40 am
by angelf1974
Thank you.
The ECU cleans the VTC mechanism occasionally. When it does, the VTC reaches the mechanical stop at 50º. The good thing is that occurs at low rpm (2000 - 3000) but we must not forget.
Re: 2008 TSX VTC
Posted: Fri Jan 03, 2014 2:57 am
by rjrawlings
The ECU cleans the VTC mechanism occasionally. When it does, the VTC reaches the mechanical stop at 50º. The good thing is that occurs at low rpm (2000 - 3000) but we must not forget.[/quote]
Well theres something i didn't know. :)
Re: 2008 TSX VTC
Posted: Fri Jan 03, 2014 5:23 am
by angelf1974
Take a look:
