B18 GSR Upgrades Base map
bono
Post by bono »
Hi guys, I need a base map for my EK4 swapped B18GSR with the following upgrades :
Skunk2 B series Stage 2 Camshafts + Adjustable Cam Gears
Skunk 2 Pro Series Valve Set / Retainers Pro Series
Skunk2 Intake Manifold + Skunk2 Throttle Body Black Series
StreetPro Gasket
Blox 330cc Injectors
Skunk2 Composite Fuel Rail
Forged CP Pistons 81mm 11.0.1 Compression
Manley Conrods
ARP Bolts
ACL Bearings
OEM Type R Oil Pump & Water Pump
4-1 Manifold
GEARBOX :
S80 4.4 Final Drive
My tuner not available so I need an urgent base map, our fuel ron here is around 93-95.
