hi everyone!
yesterday after 1:15 drive to go to the Alps and a good part of the road in the rain (see the heavy rain) I get to destination
and when to cut engine light "Systems check" therefore appears I connect the FlashPro and log
I said "P0172 system too rich (bank 1)
So this morning removing the filter, check dubody throttle (which was rather dark and fat dimension manofild
then start the engine running without worries about is 4 feet, so a ride is needed and everything is ok
the vtec starts normally, no holes in the acceleration slowed normal ...
but the light is always!
my cars FN2 K20Z4 (injen, body throttle J37, manifold intake skunk2, rh circuit sport, invidia, flashpro)
HELP ME! thank you
code P0172 flashpro
Re: code P0172 flashpro
plug the FP to your car, go to FP manage, error codes and erase the error code.
if this comes on again you have a problem, I think it's the injen. You need to calibrate the MAF sensor.
ok thank you
but after two days and everything was ok
you have an idea and it just come?
little help if you ---->
http://imagesia.com/sans-titre_aiv4
