Ariel Atom K24Z7 CT-e S/C *urgent*
VitViper
Post by VitViper »
I need assistance in getting a calibration with an immobilizer defeat so I can tune a customer's Ariel Atom that they just installed the CT-e "stage 2" (3.15 pulley w/ 1000cc inj) supercharger kit on the 2012 Si motor.
Obviously having a hard time getting spark right now... and I completely derked and forgot about the immobilizer initially. The Atom had a map from you on it when it was N/A.
What do we need to do to get this done? Get you the FlashPro?
Re: Ariel Atom K24Z7 CT-e S/C *urgent*
There's nothing you need to do / can do on your end. Tell the customer to ensure the immobilizer is disabled before they upload.
VitViper
Post by VitViper »
Hondata wrote:There's nothing you need to do / can do on your end. Tell the customer to ensure the immobilizer is disabled before they upload.
I will pass that on.
But the scenario is such: it was running on the original tune that was on the ECU (even after they put in 1000cc injectors -- they started it and obviously it ran like crap). After they flashed my FlashPro basemap for the S/C configuration the car has no spark. Only thing I can imagine causing that is the immobilizer (although the injectors fire).
Rsfariel
Post by Rsfariel »
I am the client he is referring to. How do I disable the immobilizer besides waving the key fob under the dash as we've done many times before just before starting.
I've already done that before loading Vits tune but we get no spark. It cranks but no spark.
In FlashPro Manager, go to the Calibration window and it is under Misc, Misc Parameters.
What is the serial number of the FlashPro?
VitViper
Post by VitViper »
We had the wrong FlashPro -- correct one ordered. Got the info from Doug, thanks!
BWelbourn
Post by BWelbourn »
Hondata wrote:In FlashPro Manager, go to the Calibration window and it is under Misc, Misc Parameters.
More detail please... Which option under Misc Parameters needs to be disabled in order to disable the immobilizer? I have attached a screenshot for your reference.
It will only show up on FlashPros that have special programming for TMI.
jcnicolin
Post by jcnicolin »
VitViper wrote:We had the wrong FlashPro -- correct one ordered. Got the info from Doug, thanks!
can you help me? wich one do you order, im in the same problem, crank but wont star !
Sick13
Post by Sick13 »
@VitViper I cant PM you for some reason, probably because I am new to the forum, but I was told you are THE one to talk to about flashpro tuning. Was curious if you could PM me so I could ask you some questions.
You must contact the manufacturer of the vehicle for assistance with this.
