tps issue
Posted: Sun Jul 21, 2013 7:19 pm
by fugazzyek
hi fellas
one question, what issue did you see on this image about my tps?
and i just where feelts a hole on the acceleration.
thanks for your help
Re: tps issue
Posted: Wed Aug 07, 2013 12:49 pm
by LK7R
It seems there is sharp change in IGN in your cal. Post it up. I do not see anything worng with TPS. Did you have your gas pedal all the way down to the metal?
Re: tps issue
Posted: Wed Aug 07, 2013 2:17 pm
by fugazzyek
LK7R wrote:It seems there is sharp change in IGN in your cal. Post it up. I do not see anything worng with TPS. Did you have your gas pedal all the way down to the metal?
Yeah thats the problem is WOT..
Re: tps issue
Posted: Wed Aug 07, 2013 2:46 pm
by LK7R
In KManager > Knock / TPS > Scale TPS. Check what readings will TPS give you for 0 and 100%.
Test good working TPS off another car if you can, to make sure that it is not faulty TPS.
Re: tps issue
Posted: Thu Aug 08, 2013 7:15 am
by fugazzyek
LK7R wrote:In KManager > Knock / TPS > Scale TPS. Check what readings will TPS give you for 0 and 100%.
in fact the values are 1.4% and 103%
Re: tps issue
Posted: Thu Aug 08, 2013 7:23 am
by LK7R
That's ok. Is the issue there, eveytime you do a WOT run?
